Aussiecroc
- Oct 28, 2019
- 109
For five years now caravan and motorhome folk in Australia have been adding this fridge to their rigs. The reason? Power consumption for a fridge this big is awesome. Just over 2 amp/hours at 12.8 volts on average. You get a 71 litre freezer running at minus 21C and a 158 litre fridge running at about 3C in one awesome package. I just bought a second hand one and filled it with food and it uses just over 52 amp hours a day. Many fridges that are much smaller (12 volt compressor) use as much power. This little beauty runs on a 240 volt 300 watt sine wave inverter easily. It cruises between 40 and 75 watts in normal usage and uses 1.6 watts when the compressor is off. The defrost cycle uses 120 watts. The dc motor is on most of the time and it is super quiet. This is a 240 volt fridge so my US folks would have to check out the 120 volt one and see if it does just as well. These fridges are bolted into many caravans and motorhomes and many have done mega miles on some of our worst dirt roads in the outback. Don't take my word for it -read about it in this forum all 8 forum pages full. Nobody yet has said that they will go back to 12/24 volt fridges. If you live in a cooler climate your power usage could be less than our hotter climate. This is a great fridge for home or the RV for ruggedness and low power usage. You will need to add a latch to the magnetic door and bolt it to the floor (or secure it well) for travelling. Should go great with a 200a/h 12 volt battery with adequate solar set up or similar.
the figure on the meter below is for ten days in a house with hot weather over 30c.
