100kWh = 1,953.1 Ah @ 51.2V (48V system with LFP)
7X 48V/280AH = 1960AH. 112 Cells to make 7 Packs (one day per above) .
Using Luyuan Tech: 16 Pcs 3.2V 280Ah DPP Delivery Included = 7 Pieces $16,199.90
Add 7 BMS' Fuses & Cases @ $400 USD ea = $2800.00
The Solar Array, Charge Controller(S) & Inverter setup would also be QUITE EXTENSIVE and if you think the batts cost...
RULE 1 !
Conservation is ALWAYS Cheaper than Generation and/or Storage. ALWAYS !
A proper & Full energy usage calculation has to be done. Inefficient Energy Hogs (Like the 1960's fridge you inherited) have to be identified and replaced IF possible. Heating & Cooling inefficiencies must be addressed as that is a likely culprit for energy waste.
It's AMAZING... I have temps of -30C/-22F to 40C/104F, I keep my home at 22C/72F in Winter and it never goes above 26C/79F inside in summer due to the design of the house. NO AC System, Gave it away as it is not needed. Daily energy usage is 4kWh on average. And I am 100% Offgrid and have everything I need & want. The Home has a LOT to do with it though and there is where a major line is crossed, between a conventional house build and one built for high efficiency. Sadly Energy Efficiency is NOT genuinely addressed in current Building Codes world wide but the Building Industry is also highly resistant to do so as well ass it changes a lot of things.
Ironically unfunny thing.... Why is it that folks in Hot Regions just cannot wrap their heads around Insulation as a Money Saver when it comes to COOLING... Even if you rarely or never have to Heat the home, you will likely have to cool it and insulation keeps the cool IN and the heat OUT and that saves a ghastly amount of energy & cash.
Even things like installing the Siding System as a "Rain Screen" system which creates a Thermal Break that passively diffuses the radiated heat from sun & environment away from the structure... Or people refuse to consider a Cool Roof System that also acts as a Thermal Break from the Roof Skin & the actual structure thereby maintaining the interior temps much lower. Cool Roof system alone can drop almost 50 Degrees of heat transfer into a roof but it still is NOT a standard in Hot Climate Zones and it works equally well in Cold Temp Zones too as it prevents the cold from being literally sucked out via thermal exchange.
Realize that just the Roof Design alone can save you over 33% of your Heating & Cooling costs within a year. Do the math, the conclusions are obvious but they do NOT favour Big Power & Gas Companies but favour the Homeowner and their wallets.
TWO PDF's related to Cool Roof System which can be done on a New Build as well as a Retrofit to existing buildings.
Good Luck.
