Hello,
I'm looking to set up stationary panels for an Ecoflow Delta Pro in Southern California. I'm hoping to cycle it as much as possible.
This is my plan:
6x of these used REC panels set up 3s2p. I believe that gets me:
(260x6) = 1560W -- staying under the 1600W max input
(37.8x3) = 113.4 VOC -- staying under the 150V max input
(1560/113.4) = 13.76Amps -- staying under the 15A max input
Question #1 Am I calculating that right?
Question #2 -- The Delta Pro might have to be 40 feet away from the panels. I was planning on using the 8-AWG cable recommended by Will. I'm getting confused looking at the DC wiring chart. Do I need 6-AWG cable? Does the total run include both positive and negative (is it really 80 feet, requiring 4-AWG?)
Question #3 -- Should I add OCPD fuses?
Thanks in advance for the help!
Dan
This is my plan:
Dan
