I'm trying to get my head around all this, so would appreciate some help.... I'm looking at an offgrid situation and I'm just trying to understand how power will flow....
So I'll need about an 11kW system for my needs... so lets say 50x300 watt panels.
I'll also planning on about 8, 100aH 48V batteries. and then putting on a propane generator as backup.
So let's say on a cloudy day I'm getting 6kW from the panels, But I'm drawing 8kW of power..... my assumption is that I get 6kW from the panels, and 2kW from the batteries. Then when my AC shuts off, and I only need 2kW of power, I'll get the 2kW from the panels, and the excess 4kW being generated is used to charge the batteries. - Is this correct (more or less)?
So then my assumption is that when the batteries are empty, or can't supply enough power to make up the difference between load and solar, that's when the generator kicks on. So at that point the generator will put out 10kW of power (assuming a 10kw generator) which will make up the difference in load with any remaining power charging the batteries, but will it then shut down once the load is less than the solar generation or will it shut down once the batteries are filled to a certain level?
Or do I have this all wrong in my head? any enlightenment would be greatly appreciated.
