Thanks ToacomaJoe. I will have solar and a lithium battery bank also. I'm presently in the stage of designing a power system for my t/t.No problem as long as your battery has a good charge to handle the parasites and keep a level to run the breakaway brakes. I have solar on my trailer with lithium battery so I have my 7 pin circuit disconnected to save my alternator.
A switch at the Travel Trailer is a good idea. I plan on rerouting the breakaway electricawire to the battery bank bus bars anyway. I will be doing away with stock deep cycle battery off the T/T tongue also. So tracing down the 7 pin 12v wire shouldn't be a problem.It can be disconnected at the Travel Trailer. I would put a switch on it.
As I'm in the process of designing my system, I'm trying to incorporate any issues that I see as I brainstorm through the design. I would prefer to stay away from a dc to dc charger and not even have to deal with any problems with my alternator or a dead truck battery.I put a switch in at the trailer end. In my plan I had the original FLA and added LiFePO4 so I put a 3 way switch on the truck 12V so I could direct it the FLA or to the sense of the DC/DC charger or to just neither. The alternative would be to just pull the fuse/relay in the truck to kill it completely.
What sticker are you referring too?I kept one FLA on the tongue and the original breakaway switch wiring. The wiring has no fuse or breaker (this appears to be common). Sticker indicates FLA legally required. The LiFeP04 does not have the low temperature rating. I use a 2-Bank battery switch to separate the systems.
2 bank battery switch
You need to have the vehicle charging circuit connected to keep your breakaway battery charged.would that cause any problems with my travel trailer while towing
I was going to rewire the breakaway to the Lithium battery bus bars in the pass through.You need to have the vehicle charging circuit connected to keep your breakaway battery charged.
If the charging circuit doesn’t disconnect key-off use a relay as suggested.
"SAFETY BREAK-AWAY SWITCH WILL NOT OPERATEWhat sticker are you referring too?
If I keep the 12v LFA Deep cycle on the trailer tongue for the breakaway, can I run a dc/dc charger from the same bus bar that the solar will be on after the mppt ties in?"SAFETY BREAK-AWAY SWITCH WILL NOT OPERATE
unless connected to a power source equivalent to or greater than an automotive type 12 volt, 12 amp hour wet cell battery."
IMHO: An LiFePO4 at 20F cutoff is not equivalent.
The switch wiring is typically not fused and does not run near flammable material. Any modification can add to liability.
I wish I knew what the RVIA required, but you need to spend hundreds and get training to see their codes.
IMHO: Recreational Vehicle Industry Association engages in an unsafe practice by restricting access to their codes.
I don't worry about keeping the FLA charged. The only load is the Tongue Jack. My 2020 Rams adaptive charging runs up to 14v sometimes. My Victron Smart Shunt reports the "Starter Battery" (Tongue Battery) is 12.77v. Good enough.If I keep the 12v LFA Deep cycle on the trailer tongue for the breakaway, can I run a dc/dc charger from the same bus bar that the solar will be on after the mppt the in?
Will this keep the LFA battery charged?
If not, then I will have to find another way to keep it charged.
I want to take the tow vehicle charging circuit out of the picture. My plans are to either;You need to have the vehicle charging circuit connected to keep your breakaway battery charged.
When I am settled down for the winter, not towing, I can rotate my A-B bank switch to both, long enough to level up the FLA battery. I retained it's 30A self-reset circuit breaker.I want to take the tow vehicle charging circuit out of the picture. My plans are to either;
A) rewire the breakaway power source to the 12v bus bar in the Travel Trailers pass through where the multiplus II will be. Or;
B) keep the breakaway power source wired to the stock FLA battery and charge that battery with a dc/dc charger from the bus bar that the solar mppt outlet goes to.
I don’t understand that. Just charge the brake battery with the vehicle- not the rest. You’re making something quite complex out of a very simple thing.want to take the tow vehicle charging circuit out of the picture.
Maybe I'm missing something here. Does the 12v wire coming from the tow vehicle by way of the 7 pin go straight to the FLA brake battery on the trailer tongue?I don’t understand that. Just charge the brake battery with the vehicle- not the rest. You’re making something quite complex out of a very simple thing.
