Hi:
I have an small RV (Clipper 17FQ) that I'm converting to a 24V Lithium battery with solar and shore power charging. I don't want to charge the battery with the towing vehicle power using the 7 wire connector. I tried to follow the wiring to see if I need to disconnect one of the wires from the trailer harness but I was not able to clearly understand the wiring. So my question is during a conversion like this (24 battery using a 24v to 12v converter), how to make sure that the vehicle power is not going to backfeed into the system? Should I add a diode on the 24v to 12v converter? Attached is a diagram of the my conversion. Thanks
