Hello everyone. First post!
Here’s my setup;
4 x 145W panels in parallel pairs.
Tracer 4215BN with the MT50 display.
Victron BMS 12/200.
2x 12v 100 Ah Victron Smart Lithium batteries.
Victron BMV712 monitor.
Tracer User settings:
Temp Co-eff : 0 & temp monitor unplugged
rated voltage : Auto
Over voltage disconnect 16v
charge Limit 14.1v
over voltage reconnect 14.2v
equal charge 14.1v
boost charge 14.1v
float charge 13.6v
boost rec 13.2v
low voltage rec 12.6v
undervoltage rec 12.2v
undervoltage warn 12.0v
low voltage disc 11.1v
discharge limit 10.6v
equal time 0
boost time 120
I’ve chosen that BMS because it allows me to charge the batteries using the alternator in my narrowboat when we move it.
The issue I’m having is that the Tracer isn’t actually charging up the batteries. Ok, it’s winter here and the sun isn’t great, but I should be getting something. I found the setting to plug in to the Tracer in the User profile here in the forum, but something isn’t right. The Tracer won’t raise the voltage above 13.4 (the current battery voltage) and it permanently thinks the batteries are at 100% SOC.
I've tried turning it off and on again.
Do I need to get a new MPPT that actually understands LiFePO?
Here’s my setup;
Victron BMS 12/200.
charge Limit 14.1v
equal charge 14.1v
boost charge 14.1v
float charge 13.6v
boost rec 13.2v
equal time 0
boost time 120
