Mike Jordan
- Jun 15, 2020
- 414
Sho is purdy. Tells us more
Can you please provide a part list for your build?I built up this pack and dropped it into a Todd Universal Marine Battery box. It is about 1" taller, wider and longer than a group 31 battery box. Heavy duty and fairly reasonably priced. Todd Universal Battery Box
Indeed I have checked. I can definitely find one that would fit 4 cells of the 280 AH variety.I've had that thought several times. Have you searched through any measurements?
Good point Gazoo. I don't think you need 3/4 inch though. The plastic bottoms and sides are fairly sturdy, and I think that 1/4 inch would be sufficient.I do recall someone using a cooler. I think the only problem is the thickness of the walls if intending to use battery posts. Of course there are several ways around that. For example one could use Anderson connectors to connect between the battery and an inverter.
I do think a cooler would be fairly sturdy. A box that won't flex on the bottom would be good to prevent stress on the cells terminals. If it flexes, throw in a 3/4 inch plywood in the bottom then you should be good to go.
Looks great, what are you using as a case here?
I keep thinking 8 cells because that's what I have. I know coolers are fairly sturdy and I agree 1/4 inch plywood might do the trick. My only concern is any flexing on the bottom which would cause the cells to shift and put stress on the terminals.Good point Gazoo. I don't think you need 3/4 inch though. The plastic bottoms and sides are fairly sturdy, and I think that 1/4 inch would be sufficient.
Point one, stress on the terminals and cell walls is a big no-no for sure. Yu are correct, my first set up will be 12 volt 4 cells, so I think that thinner ply is good. But your point is valid once i turn to 24V systems.I keep thinking 8 cells because that's what I have. I know coolers are fairly sturdy and I agree 1/4 inch plywood might do the trick. My only concern is any flexing on the bottom which would cause the cells to shift and put stress on the terminals.
The other thing I thought of is heat build up if running the BMS hard for long periods with the cooler cover attached. But other than that and the thickness of the walls I think a cooler is a great idea. I have seen one member house all of his equipment in milk crates...lol. And there is nothing wrong with that either...simple and effective. I have been looking at the Arko-Mills stuff too. But the rated weight capacity needs to be taken into consideration.
I also found this 20 gallon Husky box at Home Depot. Unfortunately the inside width is 13 inches and I need 14 inches. I measured it myself. It would work if I installed the cells on their flat side but I really don't want to do that. Husky also makes a 12 gallon version of the same box. They have a rated weight capacity of 500lb's and 200lb's respectively.
No doubt plywood would be a good idea for any case. Even the metal ones sold by Amy and others. The reason I don't want to go with a metal case is because it's much easier to drill holes in plastic and mount things.
Or buy a BMS that has a temp probe attached to it. Overkillsolar BMS's are popular. I have the 24 volt version and it came with two temp probes. The 12 volt version comes with at least one temp probe, I don't think it comes with two. The high and low temps can be programmed, as can everything else.I can always put a temp probe in the box.
<30*C/86*F should be a very healthy and conservative limit. From what I have read, at <0.5C and especially at <0.25C cell temperature should be within a few degrees of ambient.Everything I see and read, including Will's reviews, indicates that ambient temperature for LIFEPOP4 batteries should not likely exceed 30c or80f.[86F]
My uneducated guess is that you are right. But I don't know enough to have an educated guess. I have seen rough calculations of how to determine how many Watts a heating pad needs to be to heat batteries in an insulated box. I suppose this math could be done in reverse to figure out the effect an insulated box would have on heat generated from the batteries and BMS if you could figure out a rough figure for how much energy was being converted to heat within the box. OR... you could just try it and see, and not overthink everything like I doI think my use case will be OK and that the cooler walls will tend to mediate temperature in both directions. I can always put a temp probe in the box.
A temp controlled fan....lol. It could be mounted in a cooler to keep everything neat and the BMS inside the cooler but I think it would be somewhat of a pain.@Mark44 and @Gazoo I've been thinking about a cooler as mentioned above. I would think a cooler would be more supportive than the HD totes. In an RV application like mine, I do not think there would be enough energy movement in the batts to cause the cells to heat. I am thinking about attaching the BMS on the outside of the cooler to negate a BMS heat trap. But if you guys find a good solution, post pics
Thank you sir, Still in progress but have taken few months off on it due to other projects. I really need to get fired back up working on it.Sho is purdy. Tells us more
I'm using a pelican 1440 caseLooks awesome, what are you using for a case?
Wow, thats fancy. I like itThank you sir, Still in progress but have taken few months off on it due to other projects. I really need to get fired back up working on it.
More photos of it can be seen here https://www.timshelnut.com/Electronics/Other/Solar-Power-Generator-
Actually Gazoo, that is almost exactly what I was thinking. The BMS will disperse a limited amount of heat, but I assume since my discharge rate is likely to be .25C to .4 C it should not play a large roll. I was actually worried more from a heat perspective in terms of keeping the battery box warm enough, as opposed to cooling it.A temp controlled fan....lol. It could be mounted in a cooler to keep everything neat and the BMS inside the cooler but I think it would be somewhat of a pain.
That ain't fancy, That's freaking awesome! I can only hope mine looks half as nice as this. Way to go Tim0Shel a thing of beauty and lloks hella durable!Wow, thats fancy. I like it
I suggest searching "server power supply" "meanwell power supply" "computer power supply" maybe "HP power supply" etc on the forum, there have been a number of discussions on this in the past 4 months or so. I don't recall what subforums or where exactly or I would give you a direct link, but it shouldn't be too hard to search for.So I need to ask another question. Completely in the ditch as it is not about cases. If I need to move the question would someone please tell me where to put it?
I am considering an inexpensive power supply from a server, as the base for a charger. Does anyone know if that type of power supply can be pushed to a voltage that would work with a LIFEPO4 battery? With such high amperage, I am concerned about trying to use a buck/boost converter to get 13.4 for absorption. So I need the brain trust to weigh in!
Thank you for your kind words!!! One thing I can tell you from experience is keep it simple not so much looks make it functional as possible and its too easy to overthink things for sure. I am starting to put so much in it I have designed some 3D prints to extend the rear of the case for all fusing and wiring. Hope this will provide room in the top half of the case for inverter to fit. My issue is finding one to fit in the size I want.That ain't fancy, That's freaking awesome! I can only hope mine looks half as nice as this. Way to go Tim0Shel a thing of beauty and lloks hella durable!
