Attached is a drawing of my layout. Just seeing if anyone sees any issues with my process. I have 5 EG4 6000XP inverters all hitting a combiner panel with each on 40a breakers. Out of this combiner panel I go to my transfer switch (Siemens DTNF324R by the way I'm switching my neutral so nothing goes back to the grid). Also going into transfer switch is my grid power so I can choose between Grid and solar. And of course the load comes out to my house's main panel. As you can see I left my disconnect this is my first line of disconnect and we are bonded at this location. Past that all my neutrals and grounds are separate. To add, I have a 27 KW generator that connects to the inverters and is auto started if my batteries need charging when the panels are not enough. I'm open to any ideas or suggestions. I know there are many ways to achieve this process. Just want to be certain I'm doing things correctly and safely. Thx
