Ruff
Still learning things the hard way
I am on grid while I relocate my panels to their forever home north of the building. Last week we lost power from the grid and I needed to switch over to the batteries and inverters for a few hours. Since the system was cold and dark, it took some time to run through the start up sequence with batteries and inverters. In doing so I threw the 200 amp breaker in the main breaker panel to off before throwing the manual transfer switch from gid to solar, then threw it back to on to get power back on.
This got me thinking... Which would be better to use as a switch load wise? as in - less likely to cause an arc or fire. The main panel is a standard 200 amp Eaton panel and the manual transfer switch is a Siemens 200 amp 600 volt 3 wire double throw switch.
Seems to me that the transfer switch would be the less likely to wear out or cause any arcing?
Jeff
Jeff
