cwlutterloh
- Sep 23, 2022
- 15
Hello, new to Solar. In contract for install in a few months. I know the basics but still have a few questions. I'll have a grid-tied system using micro inverters. I know my system will be OFF not producing power when utility power is down as it is, so solar power doesn't get pushed back to grid to harm utility workers. With that said...
I would like power critical circuits. (refrigerator, freezer, wifi) I'm trying to see if my understand is correct and what all is necessary.
If power goes out and I have a manual transfer switch, I'd need to first switch OFF my main power then switch ON the transfer switch that would power a subpanel that would supply solar power the "critical" circuits in the main panel. Is that correct so far? The installer is offering to add a backup battery but 15K is too steep for my pocket book.
Do I "HAVE" to have an inline battery or separate inverter in the mix? Can't I just transfer the solar power directly to the preferred plugs? If so where does the excess power go if the load on the critical circuits is lower than what’s produced also what happens if I have too much load those circuits to power all plugged in?
My plan was to use transfer switch and plug a Bluetti or Jackery in one of the critical circuits wall plugs to keep it topped off and use the stored power via extension cords once the sun went down.
Or am I just completely off base and need to be schooled?
