I have the dual pro version of that charger - fantastic setup and really does a nice job of charging and keeping everything in balance.
The trick with solar charging is that it happens during the daytime only, while that charger plugged in charges 24 / 7, so you can go fishing during the day and have it ready to go by morning. Solar alone cannot easily do that.
So that gives you a couple of options:
- Put enough solar near the dock to charge as quickly as possible during the day hours
- Put some solar + battery + inverter near the dock to charge that up at a modest pace, and then just plug your existing boat setup into it like you are doing now.
Right now, you are getting a nominal ( 10 amps ) x ( 2 charge ports ) x ( 13 volts) ~ 300 watt charge rate, both day and night.
If you wanted to "make it behave the same way", you could use a 1 kW inverter, 2 each 100 amp-hr batteries, and perhaps 400 watts of solar at the dock to do it.
If you want to do it with just solar panels only, and be ready quickly, then you will need something more like:
- 30 amp solar charge controller
- 600 watts of solar, possibly some facing morning and some facing later in the day
It looks like you have 10 awg wire in most of it. Perhaps add some fuses.
