Hi everyone,
I recently installed a Deye Hybrid inverter (8k SG01-LP1-EU) with two DC strings of panels (3600W each, totaling 7200W), along with a DIY 15kWh LFP battery pack managed by a JK Inverter BMS communicating via CAN to the Deye inverter, providing real-time battery data. I am planning to add microinverters connected to the inverter's GEN port, so I decided to perform some tests first.
For testing purposes, I got an Enphase IQ7+ microinverter connected to a 400W solar panel. On-grid, everything works perfectly, and the microinverter connected to the GEN port produces normally.
However, issues arise when switching to off-grid mode: irrespective of the battery SOC (tested at around 50%), the Deye inverter performs frequency shifting as soon as my DC panels produce around 2000W, causing the microinverter connected to the GEN port to shut down.
Settings I've already adjusted:
Does anyone have any idea what could be causing this or experienced similar behavior?
Thanks a lot for your precious help!
- GEN Port Use:
- Micro Inv Input: Enabled
- ON: 85%
- OFF: 90%
- AC Couple Frequency: 51.5 Hz
- Set maximum battery charging current to 120A in both Deye inverter and JK BMS settings, ensuring no artificial limitation on the microinverter production.
- If I switch off both DC strings, the frequency shifts back down, and the microinverter resumes production.
- If I disconnect one DC string, reducing the total DC power below approximately 2000W, the microinverter also resumes production.
- If I introduce a heavy load (such as EV charging), the microinverter resumes production even if the DC panel production is above 2000W.
