Greetings all,
I'm struggling with an issue that I've repeatedly tried to work through GZ (who has been very supportive/responsive) but I'm afraid something is getting lost in the communication based on my lack of understanding of my system.
The System: Currently I run a GZ Yeti 1400 powered, via GZ MPPT, by 250w of GZ Boulder panels (2x 100w +1x 50w).
The Load: The panels are on the roof of my small home and the Yeti powers (via AC outlet) my internet router along with a few IoT device hubs on a power strip: 24/7. This creates a continuous load of ~30w. We also charge all of our mobile devices in the evening (phones/watches/tablets) which might push the load up to ~80-100w for a limited amount of time. All to say it seems to me like a fairly modest application.
The Issue: For my second Yeti 1400 in a row, the AC ports on the Yeti will shut off after the state of chage (SoC) drops below an ever increasing level. It starts at a low SoC and then over time the cut of level occurs at higher and higher SoCs. As an example, my current warrantied Yeti 1400 was under the described load and the AC outlets shut off at a SoC of ~30%. I noticed the wifi was down so I checked the battery, plugged in the AC Yeti charger, and by the time the SoC got up to 33% I was able to turn the AC outlets back on and have the system up and running again. Not so bad you might say, but over time that cut off occured at higher and higher SoCs until now it's happening at ~60%! This means that when my Yeti 1400 drops to a SoC of around 60% the AC outlets automatically shut off and cannot be turned on until the SoC is raised: usually no more than a few percent. (I will note that when the AC ports shut off the USB ports (and perhspas 12v outlet) still work and the Yeti's screen still functions as normal.)
The same thing happened to my last Yeti and after it started happening above 55%, and I tried all of their recommended fixes (three finger re-set and internal battery disconnect) to no avail, Goal Zero sent me a box to have it sent back warrantied. Unfortunately the same thing is happening with the replacement and I'm starting to wonder if it's something I'm doing? Is it a voltage issue? Perhaps below a certain voltage (~9.8v?) the AC outlets shut off?
Question: Does anyone have any idea what my set up or my issue sounds like may be happening?
Thank you!
Itsuo
Thank you!
Itsuo
