Hello everybody!
Will’s YouTube channel and this forum has been a tremendous help for my DIY project. I am in the final planning stages and there’s a few issues I need to clear up before buying all the components. Annoyingly, the 2424LV’s manual does not explicitly state some information that would have been helpful.
My project is an off-grid system for my truck mounted camper based on the MPP 2424LV-MSD with alternator charging. The truck is a regular cab F-150 and the solar system will be installed at the front of the camper, so right by the rear wall of the cab (to give you an idea of the cable lengths). The core of the system will be compact, so most of the cables will be quite short.
Here’s a list of questions I have that I’m hoping you guys can help me with. Please correct me if my assumptions are wrong.
- The 2424LV manual states that the inverter/charged should be connected to a permanent grounded wiring system. This implies that an isolated system is not possible with the 2424LV. The ground screw on the inverter box is for AC out, but it looks to me like AC ground and DC negative will both lead to the truck’s chassis ground through the inverter box unless the AC ground screw is isolated from the DC circuit. Does anyone have any insight here?
- The 2424LV manual recommends 4 AWG and a 100 A fuse/breaker. I used the 125% rule of thumb instead, so I chose a 125 A fuse and upgraded to 2 AWG for the inverter/charger. Should I upgrade the DC ground cable as well to 2 AWG?
- The 2424LV manual makes no mention of a ground-neutral bond and does not explain how the transfer switch functions. I plan on having a floating neutral / no bond. I will not be using a generator. In that case, is it safe to assume that the ground-neutral bond will be handled upstream at the house or the RV power pedestal?
- Based on a few threads here and on other forums, mixing DC voltages for chassis ground is fine.
- Victron Orion cable and fuse sizes are based on the manual’s recommendations.
- 2 pole DC breaker for PV disconnect. Should I use a 2 pole anywhere else or is disconnecting only the positive sufficient?
