Hi all. First time build here. Building for a small fiberglass truck camper. I need to be able to setup a relatively robust remote work environment as I'll be working on the road with starlink doing software development.
I'm struggling to nail down what components I actually want to go with.
Needs to cover:
- A couple laptops and a monitor. (this usually doesn't go past 100watts)
- Smallish DC fridge.
- Starlink (believe I'll be around 75watts here)
- Electricity for diesel heater. (small wattage)
- Occasional usage of a 300-1200 watt DC air conditioner. (imagining I'll only use in shortish bursts and don't plan too much time in hot climates, but this is a bit of a wildcard as I need to be able to control my work climate for productivity)
Inputs: (for a 12V system, I suppose I could be talked into 48v but it sounds a bit more complicated)
DC - DC is my primary (I'll be driving a lot, imagine at least an hour a day and the multiple hours every few days. Have a truck with a good alternator)
Solar - At least one 200 watt flexible panel to start, maybe two eventually.
Shore - AC charger. Don't plan using this unless I really need too. But want to build in the option.
Budget: Approx 3000
Looks like about half on batteries, half on everything else. Unrealistic? Haven't added up tools and wires/cables etc yet.
Components? Here are my current thoughts, but I want your suggestions as I'm pretty undecided. One of the big questions I have is whether or not it's a bad idea to by combo components. (inverter/charger and dc-dc+mppt)
It's kind of a small rig and I like the idea of keeping it as simple as possible. Trying 1 big 460AH battery + dual dc+dc/mppt and the inverter/charger combo would be my initial preference.
Batteries (to begin with) Figured 600ah would do the trick, but may well be able to get away with less and may start that way.
Options I'm considering
- 2x Epoch 300 (non coms)
- 1x Epoch 460 (non coms)
- 2x Sok 280
Want something with a heater built in. These seem like the best respected options out there right now. Please feel free to suggest something else or why I might want to go with one over the other.
DC-DC charger
First thought is to go with the combined Renogy DC-DC MPPT charger. (Are there any better combo dc-dc + mppt?)
Why? Less complicated, more concise to implement than separate chargers. Cheaper than going with separate components.
Outside of that... I'm probably looking at the latest Victron DC-DC offering. Any other contenders?
Yes, I've read bad things about Renogy support at times and that gives me pause...
MPPT charger
See above. Go with the renogy combo offering or probably a Victron mppt. Any others to consider?
Inverter
So I'm thinking I don't really need to go past 2000watts. Something pure sine wave, see some of Will's budget recommendations that seem to do really well and wonder if that would be good enough. But then I have to figure out a charger.
A bit turned off bit victron's pricing on the dual inverter/charger. Are there any other good inverter/charger combos that aren't almost 1,000 dollars?
And again, the dual component question.
Please feel free to suggest what components make sense and if my dual component approach is good enough long term.
Needs to cover:
Budget: Approx 3000
- 2x Sok 280
DC-DC charger
MPPT charger
Inverter
