truck cap camper build
docpusmc
new egypt nj
questiong this drawing for what i am doing in my truck bed cap camper. first time doing anything solar. I have my solar power controller battery cable going to bus bar instead of battery as well as the ship to shore battery cable going to the bus bar. not sure if this is correct or not or if this will be a problem. should these two only go to battery. any input or advice would be greatly appreciated . thank you for your imput.
thank you ,i did switch to 8 AwG. is it ok that my battery charging systems( that being solar charger as well as ship to shore noco genius) go to buss bar instead of directly to battery. is this conflictive with having everything else on same buss bar.
That’s fine. Mine is set up that way.
Electrically it’s the “same” without the possible poor consequences of stacking on terminals or duplication of cabling.
