The_Kobayashi_Vroom
So I had thought that doing 2 - MPP LV6448 and running them parallel for a 13Kw output would be a great option for us on our skoolie, but when I look at what we would need to have in order to mount the 2 + the breaker/fuse box thing with the proper spacing - I don't think we have that space. I watched a video of Will installing 1 of the MPPs and it looked so much easier than doing it all individually with my lack of experience..... but without the space for it - that's not an option - unless the way I watched on the YT video isn't the only way we could install it.
So I started looking at the Growatt 48V SPF 5000 ES 5KW with reducing our spreadsheet a lot - because that is the highest one I could find that is only 1 inverter/charger in one and maybe combining it with the EG4 48 V 100aH battery(ies).
Does anyone have any suggestions on if I am going the wrong direction here? We are still doing some framing, but I don't know if we can make adjustments to account for 2 of the MPPs - which is honestly the most ideal of options to build for bigger than we will need, but if I can always add on to the Growatt and add on the EG4s.... maybe I should start out with what I know I can handle in our bus - and then add on to it when we are somewhere permanent?
Thanks in advance,
Amanda
Thanks in advance,
Amanda
