RecoilFreak
- Jul 15, 2022
- 1
Greetings! I am in very early planning stages for our hybrid solar setup. I have 15 Schuco MPE 225 PS 09 panels - that's the only thing we have purchased. They were offered for a stupid low price locally on facebook marketplace, so I jumped on the deal. Let me start with my expectations: I would like a grid tied system that will charge my batteries and feed power back to the grid while the grid is up and run our 2 refrigerators, one chest style deep freeze, and house lights when the grid is down.
I am looking at the Sungold Power TP6048 for our inverter. All work will be performed by me - not hiring an electrician. I plan on building batteries one at a time over the next several months - 48v LiFePo4 Eve cells with Overkill Solar 100a BMS. Batteries will come later. Right now I just want to get my panels up and feeding the grid to reduce our power usage. Our local co-op buys back power at $.05/kwh. We pay $.11/kwh. Solar panels are Shuco MPE 225 PS 09 - 15 of them. I have attached a pic of the data tag. I plan on installing 3 arrays of 5 panels each. I will have each array on an isolator, all three tied together with a combiner.
Panels, inverter, and batteries will all be installed on/in my metal shop building. My shop has a 200A panel that is fed from my 250a panel on my house. I plan on plugging my inverter into a breaker in my shop panel and back feeding through the shop panel to the house panel and to the grid. This is where I need some assistance. I cannot wrap my head around how to hook this inverter to my system to backfeed the grid. It has A/C input lugs (4 wire - ground, L1, L2, neutral), A/C output lugs (4 wire - ground, L1, L2, neutral), PV input lugs (+,-), and Battery (+,-). Does this inverter have to go between the grid and my house panel, or can I wire it up to my shop panel and achieve my goal? If I CAN hook it directly to my shop panel and get where I want to go, what do I hook up and where (as far as A/C input/output)?
