So I’m relatively new to this DIY LiFePO4 batteries but need to get moving as my old 4 x 220AH Victron GEL’s are close to stuffed after only 4 busy seasons on my barge (500 cycles, but too many > 50% I think). I've be scouring these forums for info, and several other sources. I'm an Electrical Engineer but not practicing.
Not quite sure which is best forum to post this be it this one or BMS's etc..
I have a Victron Quattro 5000/24V and 4 x 250W Solar panels with a Victron SmartSolar MPPT 100/50. Charing is also from a big 3 phase 14kw generator which I can charge via the Victron at 2.4kw , 100 Amps into the battery using a single phase, or shore power. Load is primarily AC via the Victron at 5kw max, approx. 220Amps from the batteries. I also have a Victron BMV-7xx battery monitor (and shunt).
I’m planning 24 x 3.2V LiFePO4 280AH cells as they are 1/5th the price or better vrs other retail chemistries or Lithiums for the same useable AH. Better than 1/10th the lifetime cost per kwH cycled than other lead acid chemistries, and generally more tolerant of abuse (as long as a BMS is present and chargers/loads obey any requisite signals).
Key questions:
An Electrodacus I understand can signal my Quattro (and my MPPT at the same time) if needed for overvoltage to shutdown. For low voltage my Victron would shutdown, but I’d also need to disconnect any other DC small loads I may have. I presume the Electrodacus could signal a relay on the DC loads (and the Quattro again) to shutdown if an individual cell was too low.
Is replacing a failed cell with a new one something that’s doable ? If it had substantially better capacity what would likely happen ?
Alternatively I could perhaps use a Daly BMS , probably common port (as my currents are fairly high). If using 3 x 8S arrangement and 3 Daly BMS’s I could configure for approx. ½ the peak load (allowing for one bank to fail and still be able to get by with just 2 banks). So typically 50Amp peak charging and 100Amp peak load in that situation. I’d oversize the Daly to at least be a 75Amp charging and 150Amp peak current I think. 3 Electrodacus's seems a bit $$ and complex ?
Need fuses / circuit breakers, isolator switches for Battery and MPPT and Panels , controlled relays for disconnect of loads and any charging sources that cant be signalled to disconnect (eg MPPT ? only has low temp cutoff, if an individual cell V is too high it needs to be stopped.. I gather via relay on the panel inputs ? ) .. Got get my shopping list sorted including for these bits.
Thanks..
Key questions:
- Which battery ? Xuba, Basen, other ? What price ? What freight to France ? How long to ship by sea vrs Air ?
- 8S x 3P or 3P x 8S ? Passive Balance current (35ma or 200ma) of 3P x 280AH -840AH is it enough ? Should Active Balancers be considered (1.5 or 5A) , 1 BMS vrs 3 BMS but can 1BMS handle charge/discharge current of 3P batteries 100/200Amp) ? If 3 banks, size each BMS to handle ½ the charging /discharging load for redundancy.
- BMS Daly , Electrodacus , Heltec active balancing , Chargery or Other ?
- Low temp cutoff : My Victron(s) have several thermistor methods, I only need to shut off Quattro and MPPT in a low temp case , typically over winter when unattended. I suspect both will need a thermistor to detect low temp state for cutoff.
- Failed cells.. If a cell fails can it be replaced with a new cell safely ? Should I buy some spare cells given delivery takes a long time ?
Thanks..
