waywaynorcal
I fear a battery might be failing and Renogy wants a photo of an internal resistance test on my Renogy 12v 200ah battery. I bought a tester a Konnwei KW 208
I am having trouble in the settings part of the tester. I don't know what number to input in the "SET BATTERY RATING" and which standard to input the number to.
The Select Standard page is 1.CCA (cold cranking amps) 2 IEC internal electron technical commission standard 3. EN European automobile industry association standard 4. DIN German Auto Industry Committee Standard 5. CA Cranking amps standard, effective starting current value at 0 degrees C. 6. BCI Battery Council international standard. 7.JIS Japan Industrial Standard 8. MCA Marine Crakning Amps standard O degree C 9. SAE Society of automotive engineers standard.
Any help with this would be much appreciated. Getting Renogy on the phone is an absolute chore.
Whatever the standard setting is determines the correct input from whatever my battery is. If that makes sense?
In the first test I put in the CCA with a number of 2000A. I assume that is incorrect?
below is a photo of the screen of the tester and the specs on the 200ah battery
