Guda
Superstrut Strut
- Nov 19, 2019
- 516
I had a MidNite Classic 250 burn up after 15 ish months. I was at about 180v & 20a ish. The 250 can handle 250v 63a in. I was well below that. Now I am thinking it might have been my pv arrangement. I had 6p-6p-3p. Arrays ideal for summer, winter & east. The reason for that is a few. 1st array was summer on the roof. Making a array at 45 degrees on the roof was not what I wanted to do. 20 degrees was easy & the wind does not grab it at that angle. Next I put up east to get power as early as possible. Then the winter array is mounted so I can get the snow off easy.
The 250 months ago was reporting "max amps" & a yellow light was on. This was strange as I was only putting about 20amps at max. I'm not so sure there wasn't a issue with the 250 as it was a strange version.
I just found a burned connector on a pv from the east array that gets shaded. Although I have ideal diodes & breakers, I think something is going on with the different arrangements. Like the "T" in MPPT is for tracking. So if there is different V & A coming from the pv then the MPPT must not be tracing correctly.
At this point I am on the summer array only. Something is up with the winter array that I need to figure out. I will have another AIO in a couple weeks. When that comes in I'll connect the winter array to it. The east array is just going to do nothing until I get the other 2 AIO.
I am not sure whats going on technically but I am not going to have differently aimed pv on 1 mppt any more.
