Matt-M
- Sep 26, 2020
- 38
These came preinstalled on my new Brinkley RV -- removed them to install a larger system. So it is basically new, but was removed from existing equipment.
Furrion 370W Solar Panel
Mounting brackets for the solar panel are still attached to the trailer right now - will be trying to remove them from all the sealant this week. If they come out in one piece, will include. There is no box since this came mounted on the trailer, so I would prefer local pickup in New England. I live in Southern New Hampshire, about 40 miles north of Boston. If no local handoff can be arranged, then I will consider shipping, but not sure how I am going to box the panel - it's 69 x 41 inches.
$350 for both.
- Matt
- Retails for $587.95 (but see note below)
- 69 1/8" x 40 7/8"
- 370 W Peak Power
- 41.1 V Open Circuit Voltage (Voc)
- 34.2 V Max Power point Voltage (Vmp)
- 11.36 A Short Circuit Current (Isc)
- 10.82 A Max Power Point Current (Imp)
- https://www.lippert.com/370w-rigid-solar-panel-gen-2-monocrystalline-black-2022001310
- Retails for $179.90
- 12 / 24 V Battery Voltage Auto-Select
- 50 A Max Charge Current
- 100 V Max Open Circuit Voltage
- VE.Direct Port for connection to PC or Victron Monitoring Device
- https://www.victronenergy.com/solar-charge-controllers/smartsolar-100-30-100-50
$350 for both.
- Matt
