wispitgood
At early design phase for whole home system.
My first stumbling block is how to design a ground base system which would tie into two 200 AMP Service Panels. (I have 400 AMP service to home, and home is split up into two service circuits. And to make it more challenging, each Service Panel has a Generac Transfer switch for a 23kWh propane generator.
I am assuming I could run solar arrays into 2 to 4 hybrid inverters in parallel which feeds battery rack, and the four hybrid inverters would connect to ? and how?
