You can check the voltage and if near one another between .2-.3 volts you can connect + to + and - to - with some solid copper house wiring. packs will balance out a bit. This is putting them in parallel. Are you going to use it 24 or 48v? Are you talking about the BYD? You can tell use your cell voltage and over all pack voltages.
