Shaun Sparky
- Mar 22, 2022
- 4
I went to look at a new job site on a dairy farm and due to all the load shedding here in South Africa the farmer wants to install a solar inverter system for his dairy , the cows get milked between 3 and 5 in the morning and 3 and 5 in the afternoon. The system they have there is a 3 phase system with a few three phase motors and a bit of control gear , while the system is running it draws about 19,5 Amps per phase , what i will probably be needing are two 12 Kw 3 phase inverters hooked up in parallel to make up for the high start up current of the motors . Is there a formulae i could use to work out my current draw on those 3 phase inverters and the amount of 5,1 Kw 48 Volt lithium Ion Phosphate batteries i will be needing for each inverter and then of course i will have to work out out the amount of solar panels i will be needing for this job , one thing is certain , this job is going to cost this guy an absolute fortune.
