two bluetti ac200 max in parallel
Huskydriver
Hi, I was just wondering if it was possible to hook up two AC200 Max units instead of using a B230 or B300. I have multiple uses where I'd like to have two for capacity, but then able to use one in my campervan when I go out on trips. Thanks.
Rich
It depends on what you mean by this. Can you "combine" them to a single massive circuit or single appliance? No.
Can you use two units simultaneously to power 2 different circuits with different loads on each? Sure. I do this all the time with my two units AC200 max units.
Can you use one AC 200 max to "charge" the other? Sure. You lose some efficiency, but this would work. I don't believe you can straight connect one to the other as an additional battery though.
