Little Birch Mike
RE Will's video on combining two EG4 6000xp inverters into a combiner box -
I have an ancient 200 amp breaker box to which I am adding the Reliance 10 Circuit transfer switch. The switch has a 30 amp inlet that can be powered by the output of a 30 amp generator (mine is a Champion 100520, 8750 surge/7000 continuous, < 3% harmonic distortion).
I may, or may not, need to combine two EG4 6000XP inverters. My intent is emergency backup for a full size refrigerator rated at 877 watts, 1000 watt microwave, router, LCD tv, several LED bulbs, and a 40 gallon AO electric hot water heater. From what I've been able to gather, the water heater may draw up to 4500 watts.
I'd like to use the Eg4 6000xp with a 30 amp cord as the AC out directly to the transfer switch.
Question #1- if only powering the refrigerator and the hot water heater, will one EG4 6000xp unit have enough capacity to do so, using two 48v server rack batteries?
Question #2- If two EG4 6000xp inverters are necessary, would their combined output exceed the 30 amp limit of the transfer switch? I understand that the combiner box has two separate 240 volt inputs. But what is coming OUT of the combiner box, especially the amps? Would they exceed the 30 amp limit of the transfer switch?
Sorry if these questions have been answered elsewhere. I'm a newbie at all of this, and would appreciate any advice before I blow up my house. Many thanks!
