andrewhack
- Feb 21, 2022
- 7
Hi all,
I have two Epever Tracer5415AN in parallel connected via PAL-ADP Parallel Adapter. Both controllers have separate sets of panels (39-40V, 2x5 panels ~350W each) - 24V system. Both controllers has different IDs as is required by the manual. The firmware is the same.
Sometimes the controllers behavior is a bit odd- the current is limited (even in sunny day and small load) and the required additional energy is drained from the battery bank. The controllers shows 39V and 4-5A from the PV panels which is less than the needed to keep the batter from discharging.
Both controllers works as is expected if they are used in non-parallel configuration (tested one by one).
Can somebody suggest any remediation?
