I must apologize. I am trying to solve a problem by asking the question differently when I post, simply as a product of my learning more each time.
I have a 100W flexible solar panel on the roof rack of my Jeep Wrangler.
With the energy it produces I was hoping for it to do two things with it when the vehicle is parked:
1) Trickle charge the vehicle's engine (i.e. starter) battery (type AGM) during daylight, AND
2) Use that solar panel to run a 4.5W appliance at all times, day or night, again, only when the vehicle is parked.
To make a long story short, energizing the 4.5W appliance off the starter battery---even if that battery is trickle charged, is a non starter. At least let's assume that.
Since I wish to run the 4.5W appliance at all times, (I think that) logic would dictate that I use the solar panel to charge an independent battery, dedicated to the task of energizing the 4.5W appliance, with enough energy in that battery to not only compensate for the 4.5W draw of it during daylight hours by the appliance, but give that battery enough power to make it through the evening hours with this constant 4.5W appliance draw.
I thought about using a LiFePO4 battery in the vehicle's cargo area--given their safety record and voltage retention with temperature drops-but as I found out, such batteries can't be charged below freezing. (I live in the Northeast US.)
I thought about using a lead acid battery but have heard (maybe not entirely truthfully) that it's not a good idea to keep such batteries in the interior spaces of a vehicle.
I thought about buying one of those LiFePO4 batteries whose charging source first heats the battery to an acceptable temperature and then charges it, but I don't want to break the bank with such a battery's cost.
From a pure power needs standpoint, I imagine that a 10Ah battery would be adequate to run the 4.5W appliance.
Maybe there is a cheaper battery warming blanket that turns on and off with temperature that I can use to heat a LiFePO4 battery while its charging. It would seem that my solar panel would produce enough power to trickle charge the vehicle's battery, warm the LiFePO4 battery, and charge the LiFePO4 battery.
Any recommendations on components to do this, other than the solar panel I already own, would be greatly appreciated. I guess a controller with temperature settings would be useful.
Is there a controller that can handle charging two batteries, let alone of different types? Am I approaching this problem the wrong way? Can I split the cable coming off the solar panel to have one side trickle charge the starter battery with one controller, and the other side charge the battery for the 4.5W appliance?
Please explain to me at the newbie level.
