So I know that inside the structure (house), high voltage DC PV wires need to be in metal conduit.
My original plan was PVC external transition to EMT in the house, to an IMO disconnect (which has non-metallic box) and I was planning on a separate ground from a metal EMT junction box, pass through the IMO box and connect to the ground bus bar in the inverter. Now, further research indicates that the IMO disconnect needs to be in a metal box if it is mounted inside the structure. That said, I also believe the IMO disconnect is redundant to the built in PV switch on the inverter.
First question. If I eliminate the IMO disconnect inside the house, if I run EMT to the inverter, the inverter is plastic/PVC case. Do I still need to run a separate ground to properly ground the raceway/conduit since the inverter is not in a metal case? And if so, can I run from ground screw in junction box, through conduit, and connect to ground bus bar in inverter?
Second - I am planning on ground all panels together with grounding lugs and running the ground through the PVC (outside) and then through the EMT (inside structure). Can that panel ground be connected to the ground bus bar in the inverter? There is ground connection from inverter, through AC circuit breaker, through a manual transfer switch, to the main panel ground. Or does this panel ground HAVE to go directly to the main service panel ground?
Hope this makes sense.
Thanks in advance for the help
Mike
Mike
