Lenny's OffGrid RV Living
I have a 3,000-watt 12v to 120v inverter wired into my 12v battery bank now and only using the 120v outlets for now. Since the 3KW has a 30-watt standby power draw, I also have a 1,000-watt inverter that I wanted to wire in as my primary inverter and only turn on the 3KW when I need to run something that needs that higher power ability. The 1KW inverter only has a 10-watt standby power draw.
Can I just connect both of them to my battery bank? I'm thinking I can but I wanted to run my idea by the group, just in case. Do I need to do anything else other than connect the cables to the 1KW inverter? Do I need to run the cables all the way to my battery bank (about 3') or just connect them to the + and - terminals on the 3KW inverter which already has 2/0 cables connected to it from the battery bank.
I have 1,000 watts of solar panels running on two Epever MPPT charge controllers and four 100ah LiFePO4 12v batteries in parallel.
