I want to use a 6500W all-in-one to provide surge power to a planned off grid cabin - Solar with a 2000W(1600 continuous) Honda gen as backup. If I use a separate charger driven by the generator, and run the inverter from the battery/charger setup - the batteries will act as an energy capacitor, charging while inverter draw is below charger input, and discharging when power demand surges.
Can an All-in-one do the same? Or do they work like an inverter charger - either charging or inverting - but not both simultaneously? Am I just best off using the AIMS 36/48V Charger (1000W) direct to the battery without the all-in-one "knowing" about it? I do expect daily demand to be below 12-14 kWH so easily handled by the generator / charger combination. If the sun shines during the day, I am alright because I intend to waaaaay overbuild the on ground solar array in a nearby clearing.
