cjdell
- Aug 31, 2022
- 17
Hello, I'm at newb at this but have lurked on this forum for a little while. Thanks to advice from "Ray Builds Cool Stuff" and others on this forum I've asked for a quote from Jenny Wu (using email jennywu896@gmail.com) for 16 x 100Ah LiFePO4 cells. She has quoted $994 (£860) which seems reasonable to build a roughly 5kWh pack.
I'd prefer to buy from UK stock but this doesn't seem possible at the moment. I am very fearful of being ripped off based on other's prior bad experiences with buying direct from China. I just want to check that we're all still happy with Jenny?
The other thing would be the inverter / BMS combination. I am limited in what I can find but it seems like this Growatt inverter is suitable and available in the UK:
It must be off-grid (I want emergency power) but it will be grid attached most of the time.
It must be controllable. I want to schedule charge off-peak nighttime and discharge daytime. Even better if I can control export/import with a Raspberry Pi...
It want the option to add solar but I won't be doing that right away. For now I just want to time-shift electricity consumption and have the option for emergency power.
Assuming the Growatt is suitable, I need a smart BMS that can speak RS485 (or whatever) to the Growatt inverter and give me battery statistics (I am a nerd after all). There is a lot of confusion about protocols...
If this works out well for me I want to upgrade the pack (maybe 16S2P) or perhaps just building another one.
Appreciate any advice that can be offered. Also huge thanks to the documented experiences of people on this forum who have already helped me get this far.
Thanks
Growatt SPF5000 ES 5KW 48V Off Grid Solar Inverter In Parallel 220VAC MPPT+ Wifi | eBay
Growatt SPF5000 ES 5000W 48V Battery Off Grid Solar Inverter Pure Sine Wave 220VAC MPPT With WIFI Module. SPF5000 ES. 1x Growatt SPF5000 ES 5000W Solar Inverter. - Rated power 5KW, power factor 1, WIFI/ GPRS remote monitoring (optional).
www.ebay.co.uk
Thanks
