I have an Eve 280ah pack and a Daly BMS.
Lately the BMS is shutting down all the time. I suspect that it is the the protection parameter 'diff volt protect' that causes the BMS to shut down.
Mine is set to 0.26V, but I often see voltage difference at up to 0.7V while discharging. That is why I suspect that it is this setting that causes the shutdown.
When the pack is resting there is no voltage difference.
When I try to change the 'diff volt protect' parameter, I cant. I can change any other parameter, but with this one nothing happens when I click 'Set'. I also tried to do a factory reset in the app, but it had no effect and all parameters remained the same. Any tricks to force change the parameter.
Are my assumption about diff voltage causing the shutdowns correct?
Please see the attached images.
