Horsefly
Solar Wizard
I built an insulated battery box for my 8S 230Ah battery (details here), and have been running lots of tests with it here in Denver until I take it up to our cabin this spring. So far it looks like if the temperature stays at or around 20°F, I can keep the battery between 50°F and 60°F with about 3.5-4.5Ah per day. I don't expect this to go with no sun for very long, but if I only let the battery get down to 50% (115Ah) it seems like I could keep the batteries warm for 25 days or more.Knowing a fairly accurate estimate of wattage needed/used (both max load and daily total) is required to plan out any system
My heated battery box (4 x 2 x 2 ft) is not ideal because the seed starting heating pad I use is on 24/7 but it does keep the box above 45F with -12F outside. Colder temps on the way but I'm confident the heat pad will suffice. I'd have better efficiency if I bothered to tape the foam board seams
My setup works for me but other/better heating pad solutions can be found on the forum
Extended unattended use combined with extended no sun days calls for a fairly large battery bank to keep things warm and running.
On the plus side, you'll have some nice capacity for when you are there.
Add my heating pad load (21w) and my inverter idle draw (25w) and I'm using 1100w per day.
with my 9600Wh battery bank (two - 24v, 200Ah batteries) I can go 8 days of no sun and keep the batteries warm.
