NowARamGuy
- Jan 20, 2022
- 8
Hello. I am new to DIY solar forum. This is my first question. Through hours (months actually) of searching, reading and youtube videos, I have finally built my system and it appears functioning, but I have a parasitic -2.8 amp loss in my system that I just cannot seem to account for. I am able to run a vacuum cleaner and microwave off the Inverter and when I plug back into shore power, the Charger kicks in and tops off the batteries as expected. Once I achieve Float status, the Charger is outputting 13.75V, however the battery is being drained.
I am aware of the DC power consumables such as the fridge control panel, Carbon Monoxide detector, shunt and the BMS(s), etc. As I turn the components off, I continue to see -2.8A at the shunt. I have gone through my settings starting with the BMS(s), Shunt and Multiplex-II and have begun to reach out to the specific help lines for those components. In the interim I thought I would reach out here and see if a discussion with those who know might have a suggestion.
I was under the impression that once the Charger reached the Float state, it would be presenting enough volts/amps to power the DC consumables as well as provide power for the BMS balance operation. That doesn't appear to be the case and I am running out of things to test. Which reminds me, I have a lot of test data that I can supply, but I thought I would hold that back until asked.
Here's my system: Victron Multiplus-II 3000 120-50 2x120V, Victron BMV-712 w/shunt, Victron Lynx Distribution, 2 battery pack consisting of EVE 280Ah cells with a 120A 12V 4S Overkill BMS.
I am open to any and all criticism...that will only make my system better.
Thanks in advance,
Paul
View attachment 94514View attachment 94515View attachment 94516View attachment 94517View attachment 94518
Thanks in advance,
Paul
