I am in process of purchasing four, 10-foot sections of unistrut channel. My plan is to secure two pairs of two, 10-foot rails in the 20-foot space between the rear and front access hatches on my bus (MCI 102AW3, 40-foot bus).
I have a set of six (6) 3x6 SanTan Solar 270watt (250 effective given aging) polycrystalline panels with cabling.
The unistrut rails will come with 8-12 short lengths (I will call them 'feet') that I can use to create/add space between the roof and the back of the panels.
My question: What is the optimal spacing? 2-3"? 3-5"? More?
With the short lengths that will be attached to the bus at the roof bow rivet locations, the 10' rails will attach to them. Then, the panels would rest on the rails and be attached with end and mid-point clamps.
Before I install the feet, do I really need them OR is it sufficient to attach the unistrut rails to the roof and then attach the panels to the rails? I hope to position the panels across the 9.5" roof so the panels do not come in contact with the roof (slightly bowed/curved roof) and they do not protrude with the 6' length to either side of the bus (unless I have to work around the black water vent and refrigerator vent that are on the roof currently).
