oscar lopez
Alright. Just spent a week trying to second guess my cells and my last braincell is asking for help.
It's a simple set up of 4s grade A eve cells and a JK BMS with the 2A active balancing.
Don't have a dc power supply to do individual cells so I rely in the BMS for the balancing, and it worked well for a few months as far as i could tell.
The story starts with a new phone, the BMS app on the new phone giving me the classic 'Failure to pair' issue, and genius me figuring i can just keep an eye on the pack voltage via the Victron app and everything will be fine. So basically not on the loop of what's been happening the last month or so.
So i got home one day to find the lifepo4 pack was off. I scramble to find the good ol' phone with the smashed screen, and after some ADB magic eventually get to display the phone's screen in the computer to find this
I started the process of changing and balancing and that's when things get weird.
- Cell 1 always lags behind while charging, by up to 100mV. Even if i stop charging and let it catch up using the active balancing, it drops back when charging again. Once balanced, and if not charging, it remains balanced.
- Cell 2 shoots ahead the other cells when charging by upwards of 50mV higher than the other, drops down back in line when stopping charging.
- Cells 3 and 4 largely stay together voltage wise most of the way through
When i get to the upper end
- Cell 1 voltage stops increasing once it hits around 3.42v, and even starts dropping after hitting that, while charging... Can't seem to be able to get it to go any higher
- Cell 2 voltage stops being ahead while charging
- Cells 3 and 4 take the lead and hit the voltage cut off pretty damn quick
These screenshots are within a few minutes of each other
After stopping charging, cells 1 and 2 settle around the 3.34v mark. Cells 3 and 4 around 3.44v, so out of balance by 100mV
Does any of this, confusing as it probably is, offer any clues of hints as to what could be going on?
Checked all the connections several times and seem good.
BMS leads also seem ok if the resistance values are anything to go by.
Cell voltages measured with a multimeter are more or less as per the BMS/app.
Have not moved cells around yet as it won't be an easy feat.
I'll keep discharging, balancing and charging see if i can get them all to top balance, but anything else i could attempt besides that?
Thanks
Thanks
