SolarNewbie2021
- Jun 10, 2021
- 2
Hey Everyone,
New to the forum as a poster but have been browsing a bit. Building a 9.7kw solar with battery backup grid tie. Not sure what inverter(with charge controller) to use due to my loads. I do know I will need a low frequency inverter because I have a huge 5-ton AC unit to power. At present, my panels provide the following:
Max Power Voltage: 41.60v
Open Circuit Voltage: 49.86v
Max System Voltage: DC 1500v
With 24 panels I'm assuming my DC operating voltage will be (41.60v x 24) for 998v DC voltage on the array.
That being said, I would need a Inverter that can handle the following:
- 1000+ DC input.
- Surge protection from the initial startup of the AC unit which is anywhere between 2x - 3x operating KW.
- Ability to handle high amps. (Just the 5-ton unit is 25amps).
- 120/240 Split phase 60hz output.
- Ability to connect to a 48v 45kwh battery storage.
- Also able to grid tie. (Hybrid)
