I'm building a system with a 3kw growatt and 48v lithium ion battery bank. The panels are about 100ft from the electronics. I'm about to do the wiring and I've read a bunch on it. Still, I'm unsure on the right setup.
I know I need to bond the panels together with grounding Lugs and wire.
And I think I'm supposed to bond things like the breaker box housing in my solar electronics together and ground them.
It seems like code wants a single continuous grounding wire through both the panels and the electronics? They are 100ft apart though, so I'd prefer to bond them separately. And separately would seem ideal for lightning, since the ground for the panels would be right there.
Also, my offgrid growatt(SPF 3000TL LVM-ES 3kW) doesn't appear to mention anything about having a grounding lug?
Anyway, any info or sources would be appreciated, as I've spent a lot of hours trying to figure out what approach is best
