johnbrutovsky@hotmail.
So I'm confused about what cables to use to update my batteries. I have EG4 LL batteries, Both version 2 and version 4 ( -S ). I have the
That doesn't help as it doesn't list part numbers for the cables. I see what looks like pin outs, but I'm not understanding the pin out information.Here
Actually that did help. Thanks. Even though I've seen that same paper several times over the weekend, this last time finally clicked in how to read the pinouts. I found that the standard RS232 adapter has the communication wires on pins 3 & 6., I'm going to make an adapter that moves those pins to pins 4 & 5 and give it another try. Now I just need to find the correct software.Here
Did you look at the listing? The cable is on backorder. Not much help there. However, I did find that same cable at Shop Solar.
EG4 has all the software and firmware for their batteries on their website. Just make sure you select the correct battery and version.I've made my own programming cable. I'm not going to try it until tomorrow though. I let you know how it goes if I can find the correct software and then reflash the firmware.
So do I use the EG4 LL-S two part firmware update on my EG4 LL-S batteries, and the multipack software on the rest of the older batteries?EG4 has all the software and firmware for their batteries on their website. Just make sure you select the correct battery and version.
Once you have the software installed then ensure you have communication with the battery and can read the battery.
EG4 for the most part uses two different softwares: "EG4 BMS Tools" for most all but the EG4 Lifepower4 V1 which require their "BMS Test" software
If you are only connecting the LL-S and the LL-V2 together you need a Cat5e cable or higher with pins 7 & 8 between each battery.So do I use the EG4 LL-S two part firmware update on my EG4 LL-S batteries, and the multipack software on the rest of the older batteries?
How are these:Hold an ethernet/cat5 cable RJ45 connector with the pins facing up and the latch facing away from you. The RJ45 pins are a pictured below depending on the color and order of the wires. T-568B is the more common one.
Just review these threads is you want to make your own cable:
First, do you have the pinout of each RS485 port.
The EG4 Lifepower4 batteries for example use pins 1&2 as an RS485 bus as well as pins 7&8 as a second RS485 bus in the same RJ45 jack.
I purchased a RS485 to USB Converter:
RS485-USB-Converter
Using a spare cat5 cable, just cut off the RJ45 connector on one end, remove about 3 inches of the outer insulation then you can connect the correct pair of wires to the RS485 to USB Converter and plug the RJ45 connector on the other end to the correct port on the battery.
Look at the RJ45 connector on the cable (With my tired old eye I use a...
I use a spare ethernet patch cable, cut the RJ45 connector off one end, strip two to three inches of the outer insulation and select the pair of wires I need depending on which pins of the Inverter or BMS I need to use.
For a normal cable pins 1 & 2 are the orange/white and orange. Pins 7 & 8 are the brown/white and brown. I even at times use several of the wire pairs in the same cable.
Holding the RJ45 connector with the pins up and facing you (the latch/lock is facing away from you) pin 1 will be on the left and pin 8 on the right.
I use these as you can never tell which two pins in a...
