Update on my 12v 3000 watt inverter so far
Crowz
Emperor Of Solar
Alabama
I bought one of these in May of last year :
NOVOPAL 3000 Watt Pure Sine Wave Power Inverter DC 12V​
$315
I wanted to give an update on how its done so far. I had bought it to run off my 12 batteries which are there to run my security cameras, home assistant pc, solar assistant pi's, etc. It has powered my workshops window ac unit thru the summer flawlessly plus the other equipment.
The reason I decided to do the update post is it just dawned on me it has been running 24 hours a day since May 31st of last year non stop. No restarts or time off. I had actually forgot it was there till just now :)
To me that's the ultimate compliment to something I own is to forget its there doing its job.
Anyways I highly recommend the thing if someone needs a 3000 watt 12v inverter. Things silent unless you get 1300 watts or more pulling on it.
I’m in a similar situation with a 1k watt Voltworks also purchased off Amazon. Been running it uninterrupted 24/7 since around the same time as you and it’s performed flawlessly. I’m not endorsing it, just acknowledging your experience and sharing mine. My unit came with a 3 yr factory warranty.
My unit is also silent with the fans only coming on when the chest freezer/inkbird combo cycles using 700 watts for about 1/2 a second. To me it’s reassuring to hear the fridge and inverter successfully go thru the electrical motions. I have audible confirmation everything is working as it should.
