IAm_Not_Lost
Hey all,
New member here, just had a couple of questions I was hoping for help with. I’ve used this forum a few times for info before and appreciate it. Off grid for about five years now, rural AZ, built our own barndominium, built our solar setup, solar vehicle setup and aux battery, etc.
Current setup, 55kw of FLA’s, two SMA 6048’s, two Midnite Solar classics, and 6,300 watts of solar. 48v system. My batteries have reached the end of their life, or soon will, and all the other equipment is in good shape, but - other than one of the Classics - older.
The panels are 265 watt panels, 24 of them, two strings of 12 panels with six in series. Midnite combiners.
I’d like to move to the EG4 lithium batteries, either the server rack or wall mount, haven’t decided, but I figure I’ll just grab two 6000XP’s for a few more thousand while I’m doing this so that everything meshes well.
My questions:
My solar array has two strings, and each set of PV inputs coming in is running about 18amps, more than what the 6000XP’s are rated for, but they have two MPPT’s each, so could I split the solar input wires (Y them) just before they hit the 6000XP to distribute the amperage? A few threads on here indicated you could parallel or pair the two MPPT’s in each inverter to allow for this. Trying to avoid buying another couple hundred feet of 10ga and spending a couple of days running more wire and re-doing the combiner boxes and surge protectors.
Second question, my current AC wiring that goes from the inverters to my AC panel is setup for the SMA’s, which were just 120 volt and you needed two to make 240 volts, so going to my AC panel there is just one hot from each inverter, combined neutral, and ground. Can I set up the 6000XP’s to just output 120v and synchronize their outputs so the wiring can stay the same? I don’t need each inverter to output 240.
Appreciate any help you can provide.
My questions:
