The new battery was the same size as the old AGM battery, so no more or less space. I am trying to figure out how to mount a shunt on top of the LiFePO4 and I think it can be done but it will be very tight.
I picked Dakota Lithium because it was the same dimensions as the AGM battery I was replacing. After looking at the EVE 280Ah LiFePO4 web site I think they are too large for the GZ cavity. Besides, I am not ready to build a battery from scratch yet. If I were to buy another replacement battery today my choice would be the new battery the AO Lithium LiFePO4 100Ah with built in Bluetooth. Will Prowse has a YouTube video on the battery and he gives it a good review.
If you can't get the shunt to fit in the battery bay, maybe try wiring it up in the top compartment where you have your charger brick. Looks like you've already drilled an opening there.
