Upgrade solar power generator system with lifepo4
rgcoish
One of the disadvantages with many solar power systems on the market (e.g. Bluetti, etc) is that the batteries are not long lasting and safer lifepo4. Has anyone considered upgrading their systems with lifepo4 batteries, for example, when the original batteries lose capacity after many cycles? Obviously the other components in the system would have to compatible with lifepo4 or be hacked to be so.
rin67630
You will neither get a mechanical, nor an electrical match.
Replacing the cells with the same will be the best method. Used the right way: LiPo is safe and long lasting as well. beside that it has the best power-mass ratio.
