I completed an off grid cabin 2 months ago and I've been powering the cabin with the Titan with 6000 watts of power. I have 2 solar arrays with 1000 watts each. Using an 30 amp RV plug to power the building with a 100 amp 16 slot breaker box . Fortunate enough to have a master electrician to wire the cabin, but he doesn't know much about solar inverters and such. Recently, I purchased an SP 6548 6500w all in one with a single SOK 100 amp battery mounted in a server rack. I'm upgrading the wattage so we can add a 12000 BTU minisplit to heating and cool the cabin. The size of the cabin is 480 square feet with loft. The shell is insulated with 3" of closed cell foam insulation. I plan to use the same 30 amp RV plug that feeds the breaker box. What size wire should I use for the AC output?
Also, is it feasible to use a gas generator to charge with the AC input on the SP 6548? My gas generator produces a modified sine wave.
