I have at least figured out what I have. 8 batteries in series 6v at 240a each, 11,520w, 6,300 usable, 3.6kw inverter, 80a charge controller and 2520w of solar with an integrated 20k generac generator, on propane. There is also a 240v transformer with the well, 2 ton air conditioner and water heater on it. Generator comes on when they are used. The system was professionally installed in 2008 and was used very little. Looks like I will keep the system, change the batteries for lithium, will double available power and go with small mini splits or inverter window ac. I would like to put in a large water holding tank, fill once a month and maybe get a tankless propane water heater. What do you think?
