Hello All!
New Member, glad to find this awesome forum.
Ok, going to try and lay this out coherently.
My current solar system (installed on my travel trailer) consists of the following:
5x 100watt Mono Panels connected to a 40amp charge controller
3x 300watt Mono Panels connected to a 60amp charge controller
8x 230ah 6volt Duracell golf cart batteries configured for 12volts
2000 watt inverter charger
We spend most of the winter down here in AZ for months on end. I want to add more solar panels to my system. Due to lack of roof space, my plan is to ground deploy the additional panels. Found a good deal on some 370watt Mono panels and plan to pick up at least 2 of those, but would like to add 4 of them.
Through dumb luck, I have the opportunity to take ownership of a brand new 48v inverter/charge controller/charger combo from renogy: https://www.renogy.com/48v-3500w-solar-inverter-charger/
3500w inverter, can handle 4400 watts of solar, max pv input voltage of 150v (145v recommended), max PV input current 50a
What I want to do is use all of my solar panels i currently have, plus the addition 4 panels and use the 48 volt controller. With a max potential of 2,880watts. I understand i'll need a 48v to 12v converter for my 12v loads. Then i can get rid of the smaller charge controllers.
My main question is there a way that i can wire this crazy mis-matched bunch of solar panels to work together on this new charger controller/inverter/beast? What's the most efficient way to hook those up? Maybe I have to ditch a couple of the small panels?
Please let me know your thoughts. Thanks you!
