Upgrading panels to Jinko Tiger Neo N-type 72HL4-(V)
mawin
Malaysia
Hi,
I have a ten year old system with badly degrading canadian solar 250 Watt panels. Inverters still performing great. I am looking into replacing all panels with
Tiger Neo N-type 72HL4-(V) 585 Watt panels.
Can anyone advise if I can safely use 11 panels in a single string for each inverter? My installer seems hesitant to put more than 10 and I cannot figure out why there might be an issue with putting 11 - they claim its over the 6000Watts for the inverter but production in Malaysia will never reach rated output anyway.
This is my inverter:
2 x SB 6000TL-21 from sma (one for each string of 24 250 Watt panels):
Input (DC)
Max. DC power (at cos ϕ = 1) 6280 W
Max. input voltage 750 V
MPP voltage range / rated input voltage 210 V … 500 V/380 V
Min. input voltage / start input voltage 125 V / 150 V
Max. input current input A / input B 15 A / 15 A
Max. input current per string input A / input B 15 A / 15 A
Number of independent MPP inputs / strings per MPP input 2 / A:2; B:2
Output (AC)
Rated power (@ 230 V, 50 Hz) 6000 W
Max. AC apparent power 6000 VA
Nominal AC voltage / range 220 V, 230 V, 240 V / 180 V to 280 V
AC grid frequency / range 50 Hz, 60Hz / -5 Hz to +5 Hz
Rated power frequency / rated grid voltage 50 Hz / 230 V
Max. output current 26.1 A
Power factor at rated power 1
Adjustable displacement power factor 0.8 overexcited … 0.8 underexcited
Feed-in phases / connection phases 1 / 1
The panels I am looking at have those specs (see attachment):
Power: 585W
Optimum Operating Voltage (Vmp): 43.53V
Optimum Operating Current (Imp): 13.44A
Open Circuit Voltage (Voc): 52.47V
Short Circuit Current (Isc): 14.07A
Module Efficiency: 22.65%.
From what I can see 11 panels will be below MPP range (11×43.53=478.83V) so I am not sure if there is another limiting factor I need to consider. Any input will be greatly appreciated!
It will still work BUT
The inverter manufacturer that I've spoke to DO NOT recommend sizing over the value indicated in the datasheet as they claim that it will reduce the lifespan of the inverter. This will also give a very good reason for manufacturer to void the warranty as you are not following the recommendation stated in the datasheet and installation manual.
I believe your installer does not want to take the risk of voiding the warranty.
You might want to consider Jinko 66HL4M-(V) or 66HL4M-BDV as they are only slightly bigger than Tiger Neo N-type 72HL4-(V) 585 but has higher power bin of 605~620Wp depending on availability.
Using this module, you can have 1 strings of 10 modules in series and the max DC power are still within 6280W.
